Water vapor in AC
droid017
Car: 96 slicktop TT swap
My 96 Z has the digital AC controls, with the 4 fan speeds. On the highest setting, everything is normal, but on speeds 1, 2, and 3, the ac blows what appears to be water vapor (It doesn't smell like freon or coolant) from the vents. The previous owner bypassed all the lines under the plenum already so I don't think its a leak under there, and the car isn't dropping any fluid that I can see. Thoughts anybody?
stewartmotorsport
Car: 1993 NA
1988 Turbo
1987 NA
2002 SL55
2002 CL63
1988 560SL
Sounds to me like the drier is bad, and is not effective in removing moisture from the system.
NolimitZ32
What the OP is talking about is the condensation coming from the vent themselves, not water in the lines. Where do you live OP? That sometimes happens in all cars depending on humidity and humidity difference inside and outside the car.
droid017
Florida, so it doesn't get much more humid. I just thought it weird that it only happens on the highest speed.
nissanfreak12
Car: 92 300zx 2+2 TT
If you can maybe get it checked out. It may be that you have a slight clog in the lines, might even be causing the evaporator to "frost" up. This is just a thought.
NolimitZ32
nissanfreak12 wrote:If you can maybe get it checked out. It may be that you have a slight clog in the lines, might even be causing the evaporator to "frost" up. This is just a thought.
This^
I live in Houston and sometimes I have problems with the evap core freezing up because of the 100% humidity we have here.
