ibzbro »
https://forums.nicoclub.com/ibzbro-u2156.html
Sun Nov 30, 2003 8:53 am
the water temp sensor is a blue wire. the wire comes into the car via the main harness. there will be a couple of plugs that come off the main harness it will be one of those blue wires. now the plugs that come off the main harness will be like an eight and a ten i belive. ok then what you need to do is take the sensor wire that comes off the back of the gauge cluster and asumming that you have it wired up correctly take that sensor wire and cut the blue wires off the plugs that do nothing and connect them if the gauge moves you have the right one. but you have to make sure the eninge is warm. i have all of my gauges working. that was the hardest part of the swap for me, i spent like 10 hours getting everything wired up and the cluster fitting right.
