Water Temp Sender
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
My gauge quit working in my cluster a couple weeks ago, so I bought a Autometer short sweep and didn't realize I would need a metric adapter. I was wondering if any one knew what size the thread pitch is on for the sender? I tried searching around, but came up short.
Autometer sells a m12x1.5 and m12x1.75 I figure one of those two gotta be it.
Thanks guys.
ripracer
On another note...I just got done searching SkylinesAustralia and they said if you remove the sender it will wreak havoc on your ecu, I thought the single wire sensor was the temp sender that is for the gauge only?
Joe
i dont know the thread pitch off the top of my head (take it out and go to ace or something) but the single wire probe IS for the gauge cluster and you can remove it if you want. just dont touch the double wire one.
ripracer
I took it to Ace and there little tool said it has a 1.25 thread pitch m12 is the size.
Autometer doesn't sell a m12x1.25 so I guess I'll have to get one of those housing that goes in the hose.
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I just re-threaded the intake side. Take your top rad hose off and stick a Vacuum cleaner hose in there While re-tapping and it worked perfect. No leaks and No problems. I think it costed me 8$ for a tap.
Shocker
Car: 89 240sxHB rb26/30
rb25drag wrote:I just re-threaded the intake side. Take your top rad hose off and stick a Vacuum cleaner hose in there While re-tapping and it worked perfect. No leaks and No problems. I think it costed me 8$ for a tap.
+1 thats what I did.
ripracer
Re-threaded it to what? The sender they sent is smaller than the hole that is tapped there already. Guess I could thread it to m12x1.5 and then use Autometers adapter.
rb25drag
ya I believe thats the size I went to. That should be all you need, Plug N Play!!
