300freekzx »
https://forums.nicoclub.com/300freekzx-u68103.html
Thu Mar 03, 2011 8:51 pm
Ok here goes my temp gauge will go up to the hot side when I am driving on the interstate or in the city. I can turn the car off while driving and the temp needle will go and go back up as I am driving along. Tonight I drove it back home with needle going to the hotside and I parked the car and let it idle for about ten minutes and the darn needle went back down. I have been trying to figure this one out for a while. Here is what I have done in the many times of trying to find a resolution. I have change both sensors on the outlet tube, I have absolutely no leaks, I have tested the thermostat I have pulled the water pump and verified it as good, I made sure I had no pinched lines on the back after my water bypass was completed, I have fully burped the car many times. I have flushed the system (at home) no debris. Could my major line that run from the bottem of the rad to the inlet hose could be closing or could there be a block in the heater core? Please help.
