justmerging »
https://forums.nicoclub.com/justmerging-u14948.html
Tue Dec 13, 2005 9:42 am
You can get a hose adapter and put it whereever you want if you don't want to mess with the factory one. I have an sr with the blitz upper rad hose and that's where my sensor is controlling my fans. This is a good option as it reads the temperature of the water coming out of the engine, which is IMO a little more accurate as to how hot the engine is. If you put the sensor on the lower rad hose it only tells you how hot the coolant is inside the radiator because it's before the thermostat.
