tokendog »
https://forums.nicoclub.com/tokendog-u83450.html
Tue Feb 02, 2010 9:05 am
I have a built SR20DET and before the build, I was having issues with my stock temp gauge and temp sensor - so I installed an aftermarket adapter on the hot side of the engine and a temp sensor.
The auto meter gauge is showing no higher than 150 degrees on the HOT side of the engine...
Now, I am using, I believe, an 91 or 93 S-ER Sentra thermostat and I know that opens at a relatively low temperature IIRC, but shouldn't the hot side of the engine be hotter than 150?
I live in Louisiana and right now its around 70 degrees outside... My upper radiator hose gets very warm, the lower radiator hose is very cool, and the radiator itself is almost too hot to touch. I am using a aluminum Mishimoto radiator with a big 16" Mustang fan that puts out around 3900 CFM.
On every previous install of this engine, I've had heat issues, so of course I am paranoid.
Any input?
Thanks!
