S14toRPS13 wrote:No don't install electric fans. The mechanical fan on the SR outflows most electric fan set ups. I have a Koyo radiator with the mechanical fan and under normal driving my temp stays around 190-195, even in traffic.
although that is true it is inefficient, I was only expressing my opinion about electric fans but if you want to get technical electric fans are much better. Newer technology, cleaner setup, more room. A lot of times people forget the amount of drag a mechanical fan puts on the engine. It has been proven you can gain up to 8 HP by just swapping electric fans maybe you won't run 190-195 but you will run the standard temperature or lower depending on the quality of fans. I doubt you will see any mechanical fans on any real race cars, not even american muscle, at least I have not. In your case since you have an after market radiator might also be contributing to the cool temps.
Edit: I forgot to mention you will also save gas but that is really noticeable on big trucks and such. Still electric fans dominate mechanical fans.
Modified by IheartmySR at 4:17 PM 2/28/2010
