Water Temp Gauge Install
nismostate
Car: all sorts of motorsports
Just wondering if anyone has installed an electric water temp gauge. Any hints?
chickentendah
Car: SR20DET Hatch
Going to do that in 2 weeks. I'm going to stick a VDO Temperature Sender inside the tap hole on a Blitz Upper Radiator Hose. All wiring to the electrical temperature gauge will be appropriately done for neatness and saftey.
msaskin
Car: cars, computers, skiing, mountain biking
I'm running a defi gauge. Drilled a hole in the water outlet off the block and used a 1/8 NPT tap for the probe. Threaded it in and boom...all done. Didn't have to buy an (overpriced ) blitz hose, nor cut my stock hose for the GReddy or Nissport adapter.
~matt
nismostate
what size drill bit did you use? so it threaded it right in after your drilled it? no leaks?
msaskin
You need both a drill bit and a tap. Go to a hardware store and get a 1/8 NPT (1/8-27) tap and the appropriate sized drill bit.
Drill the hole, then tap the hole, then thread the sensor in
~matt
vboyq
anyone know if the greddy elec. water temp is also an 1/8 NPT. i have the 1/8 NPT tap from when i drilled teh manifold for the Greddy EGT. if the greddy's not a 1/8 then which tempo sensor did u use that used the 1/8 NPT, msaskin?
msaskin
I believe the GReddy is a 1/8PT, not 1/8NPT.
I have a defi-link gauge, but it's the imperial units one, so the sensor is 1/8NPT. If I had the metric units gauge the sensor would have come in 1/8PT.
~matt
mynismo
i've got a techtom cmx-100. plugs into consult connector. works great!
f150intally
I installed the sender in my upper radiator hose using the Nissport gauge adapter. Install was simple and I didn't have to drill any hose in my the coolant housing.
http://nissport.com/catalog/pr...ducts
VitaminT
Car: 93 240sx SE
I drilled and tapped the Water neck. 1/8" NPT tap and for the guy that asked I believe it was a 11/32nd drill bit. I am running an Autometer gauge and sensor. I question if they values are impaired a bit by the hot azz exhaust manifold right next to the water neck, but it is pretty close.
