water temp + boost gaoge
jdms-14
Car: Nissan S-14
for SR redBoost:just one question, the T fitting goes to the gauge, vacum, + one hose of the fuel regulator right?(thats what ive heard) question is, which hose of the fuel regulator do i cut and which one goes to the T
water:ok, theres a bunch of wiring for this one the only one im having problems with is the one that goes to the temp sender, where do i put this one? do i have to drill somewhere in the engine? (again, thats what ive heard)or is there a specific place to put this one?
Why does everyone makes it look SO easy!!!! aghhhhh
meangreens14
Car: s14 red top sr PARTING OUT!!!
daily:2008 subaru impreza wagon(knightrider)
dont know if you've already solved this problem... but you are correct about the T fitting for the boost gauge. just cut the line right as it goes into the fuel regulator. insert T and connect all lines in respective locations. Now as for the water temp sensor... depends on what type you have sometimes, but i have a megan sensor and i purchased the greddy 38mm radiator hose fitting sensor adapter ( which goes between the hoses, which you will have to cut a portion out of...measure this carefully!... at the upper side of the radiator as the hot water goes into the radiator). i took a measurement of the megan sensor thread pitch and found a tap and rethreaded the radiator hose sensor fitting. then i would recommend putting some teflon tape on the sensor threads (only a little bit). that should be the basics of it. good luck!
180fan
Car: 89 fastback
the temp sender, you have some options. I'm assuming you've an sr so here they are. you can
1. use a blitz upper radiator hose. it's got a bung-esque kinda deal for a temp sensor there.
2. you can get a adapter that will cut into your lower radiator hose and has a hole for your sensor.
3. use a greddy radiator that has a bung in it for a temp sensor.
