Water temp and fuel gauges.
Tartan
Car: 89 240sx
I just put a sr gauge cluster in with my sr swap and my water temp gauge isnt working and my fuel gauge needle is way past the F so it looks like I have a crazy amount of gas in the tank. Also my speedometer isnt working either. It just sticks at 14kph. Just so Im sure how many wires come out of the transmission in the sr? And where does it plug in on the sr harness. There is one plug near the driveshaft thats attached to a long sheathed wire that looks like 3 plugs will match but only one reaches it. Thanks.
quiksilvia
Car: 95 s14 se
check fuses for the cluster, #2 or 3 by your feet, the fuel gauge thing sounds like a gauge prob. transmission has 3 wires i think, the speed sensor is the one fartthest back on the passenger side, should have 2 wires on it.
Tartan
Car: 89 240sx
Well I flicked the cluster tonight and then my water temp gauge started working. But the speedo is still stuck at 14kph and the fuel gauge is beyond full. Is it broken? My wiring looks fine so I dont know what it could be.
