Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Tue Feb 07, 2006 6:26 am
My experience with pullies is that they definately give a warning sign. The two that come to mind are a howling noise - especailly when cold. You'll think that a Ford power steering pump somehow found it's way into your engine bay. The other sign is a quick belt chirp at start-up or belt squealing at redline. I'll be honest... I drove Q1 for 10-15K miles with those issues. The howling only appeared at cold (45F or below) ambient temps. and went away after the car warmed up. Not smart I know, but that at least tells you that it's probably not going to be an instant failure...I finally replaced the pullies a few months ago when the wife started driving her. I can deal with something happening - with her once a car leaves her stranded she has "trust issues" for a long time.
Honestly I would just drive it... replace the belts, check for noise on the pullies, but don't replace anything unless a problem is indicated. If you have your OEM water pump at 170K I'd say your cooling system maintenence has been excellent!
Heath
