Water Pump
TuRbOS13
Car: 91 S13 Coupe KaT
If my water pump stopped working in my 240 and caused my car to overheat, could that cause blue smoke to blow out of tailpipe and engine head........from all the heat.......maybe it started burning the oil in the engine???????
Thanks,Joe
Hijacker
Car: '92 240sx Convertible
'94 F-150
You probably overheated the motor, warped the head, and blew out the headgasket.
gvenkat
Car: 1993 240SX (1st and only owner)
Sounds like a blown head to me too.
zstylelowrider
Car: 1995 nissan 240sx
if it was blown bad enough it may blow your head gasket bad enough to burn oil but i would think that you would see a lot of white smoke from your cooling system. my experience with blue smoke usually means either bad rings or bad valve guides.
480sx
Car: 1996 Pearl White 240sx
Overheating the head can also destroy your valve seals, which would cause your blue(oil) smoke.
