water pump
irichjohn
Car: 1991 nissan 240sx
i need to change my water pump but i dunnoe how hard it is to install.i went to repair shop & they are charging me for $80 just for the labor.can anyone tell me if it is better to install it by myself or just go to that shop???
Modified by irichjohn at 11:22 PM 10/9/2007
Portugese Bend
Car: 1995 S14, 2003 CT9A
Depends on your level of experience / comfort. What have you done in the past? Have you replaced the thermostat yourself?
I would say it's harder than replacing the thermostat because there is more to remove.
irichjohn
i dont have much experience on fixing the thermostat.i did change the radiator tho.anybody who is willing to help me to install this.i live in cypress,ca.2blocks away from cypress college.
DALAZ_68
Car: 90' 240sx CA18det
323-574-7555 dude im rite near dodger staidum
gimme 40 bucks and ill do it for u...if u dont already have the pump i have a brand new one i can give u for an extra 20
so ur looking at 60 in TOTAL
hit me up son ive dont this be4...
i can even provide my own drain pans
irichjohn
does ur new water pump has lifetime warranty?
DALAZ_68
irichjohn wrote:does ur new water pump has lifetime warranty?
hell yeah...autozone jigga
edit: man i just did a google maps on ur area ( near cypress college) if u want me to go to u ima need another 5 er for gas
but if u wanna come to my pad im kew with my original offer
irichjohn
but the warranty is under ur name dude.r u mechanic?
DALAZ_68
no not mechanic...just someone whos willing to give u hand...especially since i had to do this, if u ever need a new one u can just hit me up and ill get it replaced no problem...
if u want i can just sell u the pump...and u saved around wut...15+ dollars on that alone
irichjohn
sure its brand new?y u didnt use it?im willling to buy that.
DALAZ_68
i bought it for my SOHC...and i did install it, but the engine was already far to gone...
bought a DOHC from 96 and it already had a new pump and clutch fan already mounted on it so i didnt bother installing the one i had
since it was used ( for about a day) i can go to autozone and request a new one and u can come with so u can witness it.
irichjohn
I think u can only change it,if it is defected or broken.
DALAZ_68
irichjohn wrote:I think u can only change it,if it is defected or broken.
and when u have friends who work there that dont care
quinteros05
Car: 89 240sx hatch
its not hard to change i think the trickiest part would be removing the fan but changing the water pump is not that hard.... but if u dont feel comfortable doing it get someone else better safe then sorry i guess...
bcar240
Car: 1993 240SX HB
I changed mine last winter after the SOB was dripping on me for a while. It was pretty straightforward.
Remove the intake and upper shroud of the radiator fan. Then just unbolt the fan and the water pump is right there behind it with some more bolts waiting to come off. Make sure the surface is cleaned WELL of all gasket material. Also, make sure your radiator is drained before attempting all this, . Then apply gasket to new pump and reinstall. The trickiest part for me was putting the pump back on and bolted without smearing the liquid gasket all to hell, took me a couple tries before I got a satisfactory job. My trick that worked was to tape all the bolts into their holes on the pump so when I install the pump the bolts being there allowed me to center the pump precisely and then rip the tape off and start each bolt one at a time, then spin them in to ease the pump on. And since you're dealing with a gasket, it's probably a good idea to make sure you use a torque wrench unless you are good at winging it.
A lot of people have had trouble with residual air in the system after a complete drain. I read up on their experiences and when I refilled the radiator I parked the car on a VERY steep incline (hood uphill) and let it run with the rad cap off and bleeder open until the needle started to rise, then shut off. After that I topped it off, closed rad cap and bleeder, and did some tests with my eye on the temp gauge.
It took me maybe 3 hours of work in total. There is really no reason it should take that long, but I was going very slowly/deliberately, triple checking, and kept running in to check the FSM for torque specs or what have you. I just wanted to learn about the car and I had some free time. Not trying to scare you off, but this is something that if it is done incorrectly, you basically have to start from scratch. So if you're thinking of doing it youself, make sure you do your research ahead of time.
