Water pump
lazyfcker
Car: 1991 240sx hatchback
i was reading in a forum that you can change out the water pump with the motor in the car. I see more and more coolant around my water pump so im sure its bad. so if anyone who has done this before with the motor still in the car is there anything i'll have to do differently from doing this with the motor out the car? will the radiator have to come out (i have a koyo)
NoOneBetter
yes you can change out the waterpump with the motor in the car. Easy job and you dont need to remove the radiator.
lazyfcker
thanks
ILikeMy240sx
Car: SR Power
drain coolant.
Remove alt + water pump belt
Remove water pump
Install water pump
Install belt and tighten.
Fill with coolant and bleed
Easy as that
