clev wrote:Great reply, ImS; thanks. I'll follow your advice. Do you add any type of 'conditioner' to your coolant?
never. those things are snake oils.
a. those with strange chemical properties: you never know how long they last, and what happens to them after X amount of time. they could turn into tar, and end up clogging up radiator lines.
b. those made out of regular engine coolant: those things are nothing more than regular engine coolant, with a tiny bit more lubricant - in a tiny bottle, leading you to believe its somehow going to improve the life/service of your existent coolant.
c. some are just pure coolant, which in effect will simply throw your 50/50 balance off into 51%/49% which will create better cold temp performance, and add more of the lubricant properties in the coolant itself to your mix. but you can do this yourself, by adding half a cup more of coolant than water.
