I just received my replacement water pump($21, OEM, brand new, ebay ftw! ) for my rb20, the engine is out of the car. I really do not know how to go about replacing it. I see that the front shield needs to come off as well as loosening the alternator so I can remove the belt. I am worried about the crank angle sensor, do I remove that or does it come off with the cover? If I remove the sensor, do I need to mark exactly how it is on there? If someone could clear this up for me as well as tell me about any unforeseen problems or issues I may encounter I would appreciate it greatly, thanks
EDIT: I just found this topic:
zerothread?id=270043 which seems to give a lot of information on it, but still feel free to provide me with anything that may help
And no sense in starting a new thread for another question.. I just bought some NGK bcpr6es-11 spark plugs and I am not sure of the torque specs (25lb?) or gap settings(.08?), searched for that as well but had a hard time pin pointing this information, if someone could shed some light on this for me it would help me out a lot.
