Water Pump Replacement q60 Premium
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
DaRealFonz
Car: 2017 Q60 Premium V6 twin turbo
Hello everyone,
Has anyone done a water pump replacement on their q60. Mine is making a chirping sound and I have a feeling it's one of the pulleys. I checked it out today and I did see some white specs on the engine block, I am assuming its coolant that is being flung by the rotation of the belt and is drying on the block. Also, about a month ago I changed out the two air filters, what's weird is that one if dirty already, but the other is clean.... Any thoughts? To the best of my knowledge, everything was snapped back into place correctly.
audtatious
The white specs is probably just corrosion on the aluminum. It should be under warranty so I would suggest you take it in to be looked at.
Return to “Infiniti Q50 / Q60 Forum”
