water pump replacement on 96 i30 and other problems
manchini
Car: infiniti i30 1996
sup everyone. my water pump on my i30 is making puddles under my car. im kind of broke right now so my only option at this point is to fix it myself. is that doable for a guy who never done one before. I understand you have to mess with the tensioner and covers and all that. it seems kind of intimidating. can anyone give me advice or install instructions. it would GREATLY be appreciated.
also i have knock sensor , o2 sensor and evap vent codes comin on my check engine light. could that be all tied in to the fact my muffler is a mess?
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO.
Give me a little time and I'll post the water pump removal and installation instructions from the FSM.
I doubt your codes are due to a bad muffler. Probably just seperate issues with the car.
maxhopper
4th Gen water pump replacement
manchini
holy ****t. I didnt expect all this. I thank you so mucch. I have a lot of work to do on my car. it only has 109k on it. i have a bad muffler from cat back and a bad flex pipe. knock sensor problems and o2 sensor problems.the guys at meineke tried to convice me to get rid of it, but again it only has 109k and i have babied the thing. I have my work cut out for me huh? thx again. anymnore advice on exhaust and ks i would appreciate.
maxhopper
You're quite welcome. I sure don't envy you on the water pump replacement.
As for your other needs:O2 Sensor - http://www.sparkplugs.com/Knock Sensor - http://www.nissanparts.org/Cat-back and Y-pipe (includes flex pipe section) - numerous sponsors carry them check this thread. Look at Custom Enterprises, Sport Compact Only, and Stillen. zerothread/119692
As always, be sure to mention you're a NICO member when placing your orders.
manchini
where did you get that info on wp installation. i would like to get the same type info for installing the exhaust,ks,and o2 aswell as any other problems that might occur. im tryin to get into fixing my own car after many years of gettin robbed. also that diagram was great but where is the wp located on the 96 i30? thx sorry for teh novice question, im new to all this.
maxhopper
Tricks of the trade my friend, the instructions are from a 1996 Maxima Factory Service Manual. I can e-mail it to you if you can accept a 39.9 MB file.
The water pump is located on the passenger side of the engine. Your best bet will probably be to take off your passenger side tire and splash guards and go at it from there.
manchini
[email protected] dude..i will be bothering you some more. i need this fixed. 109k it shoudl be purring. instead it sounds liuke a herd of elephants
maxhopper
Yahoo only goes up to 10MB. Let me see what I can do.
Edit: I sent you an e-mail with a link so you can download it.
