Water pump replacement done, now high idle?
tjrob2000
Car: 2007 Infiniti G35 Journey sedan
Just finished up replacing the water pump on my '07 G35 Journey. Filled the system with coolant and started her up. Started first try and all sounds normal. While I was topping it off as it let out air the idle wasn't coming down. It's staying between 1400 - 1700 rpm. Temp came up to middle pretty quickly, but this has been the case with this car since I bought it 4 years ago. I'm thinking an air leak, but so far can't find any. I'm pretty sure all hoses are connected, but it's certainly possible I missed one. Any other ideas for me to look for?
Also, the coolant started coming out of the fill neck. I believe this is due to the t-stat not being opened yet (I didn't give it that much time).
Tom
tjrob2000
Sorry for the late follow-up here. This was solved by properly doing the idle air relearn.
audtatious
Thanks for the update, something we don't get often with slow posting on forums nowadays.
