datechboss101 »
https://forums.nicoclub.com/datechboss101-u271130.html
Mon Apr 02, 2018 3:20 pm
Not sure if this is applicable here, but the engine shouldn't be removed at all unless you are doing an engine swap or engine rebuild. So to access the Water pump, you could remove other parts. I just really don't see the point of removing the engine at all, as it requires lots of work to do... just remember that. Like Rogue Jarhead said, you can use the FSM that is available for all members.
