biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Tue May 04, 2004 10:46 am
RWD pully:
the exterior diamter is ~5 6/16 (are you sure it was 3/16 not 3/8?)
I measured 1 7/16ish for bolt-to-bolt spacing (it actually seems to be slightly off of that, but since we know the pumps interchange then the bolts must be the same).
The grooves look identical.
For the hell of it I measured the inside hole of the pully, its 1".
Assuming you specifically meant 5 3/16 then using a FWD on RWD would make the pump spin faster, which would lead to sooner cavitation at high RPM (but having no idea when it would begin normally, may not be an issue). However, this is easily within the range of belt adjustment or possibly just getting a slightly smaller belt.. but if you meant 5 3/8 (5 6/16) then it's the same outter diameter.
Interesting if they're different, as it would imply they intended to have the FWD version operate at a higher RPM UNLESS the crank pully was sized different to make up for it. Assuming it wasn't, then it might be no issue to run the pully w/ the smaller FWD pully.
