got an OEM water pump, came with a paper gasket. Should i use just the gasket, or just rubber gasket maker, or both? and if both, do i put the gasket maker on the gasket or the block or the pump? if the gasket, both sides or just one?? Also, should i put anything on the thermostat before i replace that??
thanks
