Water Pump or What?
MineRS13
Car: 1993 Nissan 240sx coupe
i have a slight rattle not loud or anything when the car is idling until i bring the RPMs up jus a hair and it stops. Ive heard that it might be a water pump problem but im not sure. If anyone can help me i will be greatly appreciated.
thanks
eclipse2001gt
Car: 240sx 350 small block
Does your temp go up higher than normal?Did you pop the hood then start it and listen to see where the noise is coming from?
MineRS13
last time i had a water pump problem the temp stayed normal until one day it shot up and the radiator blew...bad day for me but ive tried listening but i cant figure out where its from
blackRB240
Car: 1993 RB25 SII swapped S13 hatch
Slight rattle is normal in the KA24DE. It is the timing chain guides that are rattling. I changed the waterpump in mine and it is still doing the same thing. It won't damage anything, just a little extra noise.
MineRS13
aight thanx for the info
