DeltaZulu »
https://forums.nicoclub.com/deltazulu-u7574.html
Fri Jul 18, 2003 4:26 pm
I noticed a coolant leak from the water pump pully area of my 240SX 1990 (recently mounted 1989 KA24E 85K). I thought it was a broken gasket so, removed the pump assembly from block and installed with new gasket. Then I realized that the leak is coming from two small holes on the water pump (one on side and the other below). I checked Nisssan factory service manual but it does not cover details of water pump assembly. Does anyone know what these two holes are? What should I do to stop this leak from holes?
Thank you.
