water pump in 93 240 vert
donmeca2020
Car: 2005 lancer evolution and 1993 240sx convertible
it appears im having a water leak from somewhere under the hood, we checked the radiator, there were no signs from that, so we think the water pump has gone bad. would anyone know where exactly the water pump is located on these cars? thanks for any info
znelson
Car: 1992 240SX
Its on the front timing over, almost directly above the crank pulley. If you have a clutch fan then clutch fan bolts to the water pump's pulley.
donmeca2020
thanks for the info, im gonna try getting at that asap
donmeca2020
ok does anybody have experience taking this off? it seems to be attached to the fan if i try taking it out does the whole assembly come out'?
180fan
Car: 89 fastback
you pull the fan off before knocking the water pump off
donmeca2020
i'll give that a try tomorrow.
