water pump/fan pulleys
Nvkreationz
Car: Cars
i wonder what is the pulley called that sit between the water pump and fan...i need a new one and i dont know where to locate one or fine a used one..so it help if you can help is find one, it can be after market racing ones...and thanz guyz
JeromeS13
Car: 2008 Subaru Impreza STI
Are you talking about the pulley (which is attached to the water pump) or the fan clutch (the piece that attaches the fan blade to the water pump pulley)?
msaskin
Car: cars, computers, skiing, mountain biking
Are you talking about the crank pulley?
~matt
JeromeS13
msaskin wrote:Are you talking about the crank pulley?
~matt
The crank pulley doesn't sit between the water pump and fan....
msaskin
JeromeS13 wrote:The crank pulley doesn't sit between the water pump and fan....
I realize this, I just spaced out and couldn't quite understand what he was talking about. I always forget that the fan sits on top of that since most of the SR's I deal with (except for mine) don't have the fan in place.
~matt
gumby
Car: '89 240sx sohc
stupid question time
whats the fan clutch's function?
i2ice4m3
Car: COUNTERSTRIKE!
it "engages" and "disengages" the fan according to the radiator temperature.
hamsterball
Car: 1990 White Nissan 240SX Fastback
i think it may be the thermostat. The thermostat sits between the water pump gaskets.
Is that what you're talking about?
JeromeS13
hamsterball wrote:i think it may be the thermostat. The thermostat sits between the water pump gaskets.
No. The thermostat sits between the water outlet and the block.
msaskin
JeromeS13 wrote:No. The thermostat sits between the water outlet and the block.
actually, it's the water inlet and the block ;), unless of course it's different on a KA and an SR.
~matt
JeromeS13
msaskin wrote:actually, it's the water inlet and the block ;), unless of course it's different on a KA and an SR.
~matt
Outlet from block to lower radiator on KA-DE
RShih
IT"S THE FAN CLUTCH....
