water pump dead? coolant overflow
nyckanny
Hi, So I have been leaking coolant for the last few months now. It seems like the weep hole at the bottom side of the water pump is leaking, i'm not sure. Anyway. Today I went to get some food, and on the way back the idle rose up to about 1000 the whole drive back. In the garage, I parked and noticed that the coolant overflow tank was way filled, beyond even the max line. the fan was on full blast also, hence the high idle.
so what is wrong?
im stressed out with other things too sigh
180fan
Car: 89 fastback
change the water pump, it's done.
nyckanny
yeah, but one thing that bothers me, why would the coolant tank overfill tank get filled up so much, it was almost filled up. and after the car cooled down, the coolant overfill tank went back down to the min level
180fan
Car: 89 fastback
it's the water expanding and contracting from the heat. Another thing you might want to have checked is the radiator cap.
fatboy
Car: s13
pressure check the system, i alway throw in thermostats when i change the water pump also.
s13_drftone
Car: S13 with sr20det swap
change thermostat, and change water pump probably it need a new gasket
