DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sat Nov 09, 2002 12:13 pm
I agree that plastic is plastic, but I believe it's a fairly stout design. Ultimately, the real cause of the problem needs to be figured out before a decision is made, but here's my take. Agreed, if the plastic is cracking, then replace it (you may be able to replace only the tank). If it's a bad gasket, then I would try to repair it rather than replace the entire radiator at $400+. I have to disagree about there being much risk of destroying the block. I assume the concern is with plugging a critical coolant pathway with adhesive? The fitting is basically a threaded tube that protrudes through a hole that is probably at most 30 mils oversized. It's in the tank, right?...so it's not a critical pathway and with a viscous adhesive (and assuming full cure) I doubt any will squeeze in there and break off. Beyond that, there should be some kind of gasket behind the tank face that would most likely prevent any adhesive seepage into the radiator. I believe the only risk, and a very tiny one at that, is that some cured adhesive might get into the cooling system and slowly damage the pump impeller or restrict a single transport tube in the radiator. It's at least worth considering before plunking down over $400.
