jasonsos »
https://forums.nicoclub.com/jasonsos-u49059.html
Sun Mar 04, 2007 3:34 am
The first mechanic I called, I have delt with in the past who repaired my Jeep Comanche and Cheorkee. He said that he couldn't even get around to it for two weeks, but then I asked him to give me a quote. I said he would have to call me back but that the labor alone was $280.00, with the water pump and belt an extra $107.00.I then called another local mechanic my sister and Aunt had delt with of whom they were VERY happy with. He said he could start on it by next Thursday (The water pump started to leak and make bearing sounds on this past Friday). I didn't drive the J30 except a few blocks to get cagarettes a couple of times over the weekend). He gave me a quote of $400.00 for labor alone. I thought, based upon Jeep repairs and having changed many water pumps in my younger years, wow, that's some money for a water pump!I then called the two major dealers in the Dallas/Ft. Worth areas. The first one gave me a quote of $725.00, just to change the water pump, although he mentioned that if you changed the water pump on J30s, you HAD to also change the timing belt and several oil seals, which would cost an additional $200.00, or, $925.00 total. The 2nd dealer told me the same thing but added that all the belts had to be changed along with the seals. Both dealers are 30 odd miles away with the former quoting me $1,200.00 total, and he could fix it in one day--next week.Of course, I have no 2nd car, so my need is (was) great.The 1st local guy called me back saying that he was told the water pump could be one of three different types of pumps and that he would have to take the old one out just to see which pump would fit. He's also the one that said he couldn't even start on it until the next Thursday, being Monday the 28th the day I called.With all of this, I went to the local guy who said he could start on Thursday, take the old one out, order the new one (not rebuilt) and have it finished by Friday evening, which he did. Total cost: $387.00, and he even fixed a few things he didn't have to, like when the dealer didn't replace the bolts in the shield the last time the pump was changed by putting new ones in--free, and he adjusted the door that was a bit hard to close.This is in a small town in Texas with no Nissan dealers and was only 2 miles from my house, so I could drive it there without worries of over heating and being stranded.Was this a GREAT deal?* Only problem now that I paid him and drove home, the noise of a bearing going bad remains. I called him and he said not to worry, that it was the a/c compressor making a 'fibration' noise and that it wouldn't fail, just live with the noise and don't worry about it.SHOULD I BE WORRIED?Many thanks to you all.Jason
