jamesblonde82 »
https://forums.nicoclub.com/jamesblonde82-u38650.html
Wed Jul 04, 2007 5:03 am
i didn't catch mine in time on my 92' and the water pump froze, overheated the radiator and cracked it. i did all the work myself. i had it done in less than a day. would have been quicker if i didn't have to run to the parts store a couple times. thank God these are rear wheel drive vehicles, otherwise it would be impossible because a lot of their water pumps are run off the timing belt(s). the hardest part for me to do it was reaching the bolt that is underneath the water pump, and i did that with a knuckle attachment on my ratchet drive. after i did all the work i started it up and man she ran so cool after it. i put new belts on and everything. but, it leaked some i was so pissed...but turned out i didn't have the lower radiator hose tightened enough, so it leaked some. tightened it, and it was a flawless job, i love it when that happens. if you do it yourself, i highly recommend (depending on how long ago you did this) replacing the thermostat (especially if you overheated the engine a bit), belts, and hoses. you can't go wrong with preventative maint' hope you git er done.
