VmaN! »
https://forums.nicoclub.com/vman-u12423.html
Thu Sep 09, 2004 5:17 pm
OK, this was a bad idea from the beginning , but heres the background before I get to the problem:
I had to pick up my sister from school and it was raining heavily. I live in Las Vegas so the streets flood easily. It was early on and the water was just coating the ground, so I thought my car would be fine. When I get to my sister's school, the water is pretty high, but I had to go through because the area is under construction so I was blocked off. So basically I'm stuck, and I have to go through the water, which is about 1/4, maybe a few inches higher up on my rims. It is a 1989 240sx fastback.
So I get home and I know there is something wrong with my car. The idle is VERY rough, the car shakes quite violently, black smoke is coming out of my exhaust, and I can smell gas. I checked my air filter and there WAS water on the inside of the casing, and I also switched out the air filter.
This happened earlier in the day, so its been sitting in my garage for a few hours now. Is there anything I can do??? Thanks.
Edit: I just checked it, idle isnt as bad as it was before, but there is still black smoke from my exhaust. Also there is this screeching sound when I start the car.
