Nathan wrote:No no, this is NORMAL. It's that way for a reason, that reason being: water should circulate to the back of the engine block, then up into the head, then to the front of the head. If those passages were not blocked off it would take the path of least resistance and it would stagnate at the back cylinders leading to overheating. However, I know how scary and weird that is the first time you see itFrieked the heck out of me...
