water/meth + nitrous? anyone use? post setup please.
Fixation
Car: 92 Nissan Silvia
Have a decently built sr20, cp pistons, hks 272 cams, 2781R 750cc injectors, enthalpy ecu.
Looking for an easy way to get more performance without doing any major reconstruction. I want to get a water/meth injection kit, for only $500ish, it seems like a cost effect and easy mod.
Anyone have trial and error stories for water/meth on their sr20 they can share before i go this route?
I'm also interested in adding a small (50-75) shot of nitrous.
Will the water/meth serve the same purpose as the fuel from a wet kit?
Good idea? bad idea?
Post ur setup pics and any advice or comments on this method.
thanx
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
If you really want more performance, why don't you start with a tunable ecu like a AEM EMS or a Apexi PFC?
two40splease
I'm with PyR0NiAk, get a tunable ecu b/c you'll need it for the meth. I run Meth Injection and I tune for it myself with Nistune. I have the same turbo as you but I run a lot more timing than most b/c of the meth. I use Alky control their about the best IMO. I couln't imagine getting a mail order tune for meth there is no way to get that perfect or anywhere close.
