I really have hard time seeing it affecting rings.... Cumbustion temp. like 1000C (1832F) intake charge around 90C (194F). Coming out as mist only under high boost then turns off. Ill have to look into that, good tip sounds Horrible if true.
llv sounds amazing!!!
http://www.alternativeauto.com....html
http://www.alcohol-injection.c....html
WOW= FICTION.... this one is good Please everyone skim this one below
"Do I need engine management to run this? Yes, 100% absolutely you HAVE TO have, at a minimum, some way of tuning fuel. Because when this sprays you will go INSANELY rich, like 7-1 rich. That is rich enough to be dangerous and can cause bore wash (this is where there is so much fluid in the cyl that it rinses the oil off the cyl walls, and the rings tear themselves and the cyl wall up.)
READ!!!!
http://www.tristatetuners.com/...14745
