Bluefire »
https://forums.nicoclub.com/bluefire-u7784.html
Tue Aug 10, 2004 4:40 pm
I'm having a bit of trouble with the water lines using the greddy manifold.
1. Originally the water return line from the turbo goes into the stock intake manifold. Is it ok to just hook that line up to the heater hose outlet pictured below? Originally that outlet was for the water from the stock throttlebody.
2. Where do you hook up the coolant bleeder valve pictured below. Originally one goes to the throttlebody, one goes to the intake manifold, and the other goes to another heater hose outlet. Now since i'm not hooking up any waterlines to the q45 throttlebody, and since there is no water connection to the manifold, that leaves two empty outlets, where do they go? heater hose outlet
Please help me out so I can finish up my hosing!!!
-Bluefire
