Water leaking
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
yankeefan973
Car: 2008 Nissan Versa SL
So After the storm Jersey has gotten, I went into my car and smelled wet carpet. After further inspection, the carpet on the driver side was soaked. Anyone have any ideas on what can be causing this problem. thanks for the help
robaustin
Possibly clogged drains. There are drains that allow water to drain from up along the hood cowel to the ground. If these become clogged with debris (aka leaves get in there are other stuff) the drains may back up into the car, and they usually back up - right down along the firewall into the carpet in the front seats.
You can ask your auto repair shop to blow out the drains, should solve the problem.
Also - be careful now about mold on your carpets, you may want to clean them thorougly to prevent mold growth.
--*Rob
NCJack
Car: 2007 Versa SL
yankeefan973 wrote:So After the storm Jersey has gotten, I went into my car and smelled wet carpet. After further inspection, the carpet on the driver side was soaked. Anyone have any ideas on what can be causing this problem. thanks for the help
I believe Nissan has issued a Technical Service Bulletin (TSB) regarding this issue.
http://www.aboutautomobile.com...Frame http://www.aboutautomobile.com.../Body
Take it back to the dealer and demand they fix it!
Regards,Jack
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
the NTB is
NTB-09-010A dated July 2009
Return to “Versa Technical Discussions”
