That was our fix...maybe that's something to look into. Good luck.
Here is the TSB you mentioned: http://www.megaupload.com/?d=26YT1V4Vmysoccermom wrote:My husband and brother seemed to have fixed the leak in my '08 Pathy. They extended the evaporator drain tube (passenger side, down underneath the windshield wiper area) with a small piece of hose, checked the cowl drains but they were fine. So far, no more leak. My husband did finally call a friend who works at Nissan shop (after the fact, nice!) and did find out there is a Tech. Service Bulletin out on the evaporator drain tube issue.
Huh? The TSB applies to R51, N50, and D40 model Nissan vehicles only, not your R50, so I doubt the diagram would be of much help. I looked through the body and trim section of the FSM and only found stuff related to the drain hoses for the sunroof.Bambritt wrote:Thanks for the diagram TC.
