golgo13 »
https://forums.nicoclub.com/golgo13-u39974.html
Fri Jul 28, 2006 4:18 am
Edit: To anyone who searches and reads this topic, I solved it by using a neighbor's 3M seam sealer on the joint shown below. I put some on the inside and outside of the adjoining metal pieces. It stopped the leak.
Edit: This is from a 1990 240SX S13
Well, just when I'm trying to fix one problem, another issue I thought would be easy to resolve still lingers. When I was replacing my fuel pump a few weeks back, I found a puddle of water in the spare tire well. I searched and found the info in the faq and a nice write-up at the zilvia website about resealing the tail lamp. Sure enough, I remove the bulb assembly and felt the large puddle of water in the light assembly. I was putting this off trying to fix another problem but the constant rains made this a priority instead. So, I went and resealed the tail lamp with butyl seal. I became a little disconcerted when the previous seal appeared relatively intact and there was a lot of it too. Regardless, I went ahead proceeded to replace it.
Now, after replacing it and testing with a hose, I didn't notice anything immediately indicating a leak. However, after a rain storm a couple of nights later, I decided to check it and I saw water coming in from a interesting location. Below are pics of my findings:
Image 1: The puddle of water found. After drying it, it reappeared within 30 minutes. After some time, the water slowly stops seeping in. It appears to seeping in through a joint? (See image 2)
Image 2: A clearer picture with identifying marks of where I find water seeping in.
I guess I can just put a caulking there? Silicone? There's a seal along the metal. What kind of seal is that? It seems tougher than regular caulk/silicone. Remember, I'm a novice. Where can the water be accumulating to ultimately come in from that location?
Ok, still with me? I noticed there's still a little water in the light assembly. It's not puddles but it accumulates in a small lengthwise crevice. Here's a picture to understand. I also noticed my other lamp, which didn't have puddles of water like my left lamp, had this to smaller degree. Where's this water coming from? The butyl seal looks good. I should note that when I was resealing there was algae like substance in the crevice. Thoughts? See Image 3.
Image 3:
Image 4: A reference shot of the light assembly from above
Modified by golgo13 at 12:10 PM 8/10/2006
