j.hardstyle »
https://forums.nicoclub.com/j-hardstyle-u193508.html
Sun Feb 26, 2012 10:20 am
Its just the nature of cars to get water into the middle of the door, which is why there are drain slots and holes in the bottom of the door. There shouldnt be a ton of water, of course, but it is a common issue. They make "speaker baffles" to put on the back of the speaker so it doesnt get wet, but the Q speakers are already enclosed in the BOSE case. I just dont see any place where the water can leak into the case because there are no holes or cracks.
The water does drip down from the window track though, which was exactly what I thought. It does the same on the passengers side...noticed a bit more water in the door on that side, but strangely enough there is no water inside the speaker case.
I am thinking of putting thick plastic sheeting behind the speaker case, that way the water will just roll off so theres no way for water to get inside it....I assume somehow its making its way through the back of the case....maybe there the small bolts are. Not sure.
