Beez_S13 »
https://forums.nicoclub.com/beez-s13-u66035.html
Mon Jul 28, 2008 4:12 am
check to see if the drain line from evaporator box is leaking, condensation from evap. getting out, i could be wrong, but if its cold, then, its probably just condensation. as for the a/c losing power, is your car losing power, or is the compressor actually losing power? the compressor is belt driven, the pulley is on a clutch system. your clutch on the compressor might be slipping a little bit, or the electromagnet that pulls the clutch to engage the compressor might not be pulling properly. check the connections and voltage getting to the electromagnet.
these are all just ideas. im in a climate control class at school, so these are just a few guesses of mine.good luck
