water leak - roof J30 - how to clean out drains?
RaceBannon
Car: 1993 J30
I own a '93 J30, and recently bought an FX45, so the "J" I have parked only drive once a week.
I have had intermittent water leakage thru the Sun-roof at the control console.
Now, I opened it and Mold was growing and the Left-Side Front Passenger carpet under the mat was soaked.
I recall some yrs ago a Mechanic or the Dealer "Cleaned out" the "Water Drains", they explained to me that Infinity had designed in the drains because Sun-Roofs are prone to leak.
Anyhow, anyone know where or how to clear the drains?
driverdriver
Car: NICO's longtime resident Canuck!!!
Welcome to NICO!!!
The sunroof drainage holes are along the sides to the front of the sunroof. You have to open up your sunroof to access them.
I've used "canned" air (the type for computers) to clean them out. Use gentle blasts. The tubes become fragile over the years.
misfit6794
Car: 93 J30
If I remember right the tubes run down both the a pillers and the c pillers, on both sides.
gr8scott72
Car: 1994 Infiniti J30t
driverdriver wrote:Welcome to NICO!!!
String trimmer "string" works good too.
Defiant
Car: 1997 J30
^ Yup. Weed whacker filament. Some of it is strong enough you can chuck it up in a battery drill, too. Be careful in using compressed air, as you don't want to blow the tube off the pipe. Despite what your wrench says, most cars with roof holes also have drains built-in. Sunroofs really aren't expected to be water tight.
