Hi All,
I have a water leak that shorted out the rear lighting control module. Have the part in hand, and the shop removed the lower trim in the cargo area so they could access the module. However, I haven't determined where the leak is coming from, other than somewhere in the hatch area. If I pour water by the top of the hatch I can see water dripping down a wiring harness on the left hand side of the rear hatch. I need to remove the upper trim pieces and have a look and determine if a seal is bad. Looked online for the past two days and can't locate any diagrams or information on how to remove those trim pieces. Ideas? Anyone else had this same problem?
Thanks much,
Ron
