water leak inside 2001 altima
General discussion area for the L30-chassis Altima
Andrew300zx
Car: s13 FB
cant seem to figure this out- my wife's 2001 altima will leak cold water all over the passenger side floor. I suspect the ac- especially since the pool of condensation underneath the car no longer appears after the car is parked. I took off the glove compartment but can't seem to find the problem. My Z had a little tube that got disconnected causing a similar problem- but I can find no such tube on the altima- any thoughts would be greatly appreciated!
ultimatuc
Car: fast cars, big trucks, sluts
there is a drain tube in the ac/heater plenum......chances are its clogged. you can see it from under the car. you may want to ream it out w/ a coat hanger or something......
Andrew300zx
Car: s13 FB
thanx- actually just found it with the help of a friends lift and fixed it with an air compressor. So much better!
Return to “2nd Generation Altima Sedan (1998-2001)”
