water leak I30 1996
britcan
Car: 1997 Infiniti i30
i was loosing water . topped it up once aweek today just stopped running looked underneath not leaking at the radiator seems to be leaking about a foot back towards rear. in front of oil pan any ideas ???
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Water leak, if not addressed immediately, will lead to engine overheat.
Most likely the water pump, leaking thru the pump seals. Butt check the water cooling lines. If you're lucky, the leak maybe just due loose connections.
Replacing water pump is time consuming. So if you're not handy with tools and impatient, better leave the job to your mechanic. Let me know if you want to do it yourself.
At IoS, everythinginfiniti.com, discounted price of water pump is @ $80.
http://www.infinitipartsusa.co...gid=0
britcan
turns out to be a blown head gasket any advice costs $ 1600 here
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Ask the mechanic if any of the bottom end parts were damaged;was the piston wall scored, was there water in the engine etc. If the blockwas cracked then the engine is probably junk.
If you plan on keeping the car, you probably want to put in a newwater pump, thermostat, and timing and camshaft chains, guides, tensioner.
I would like to see how the camshafts are removed to get tothe head
