water injection
cobhc2889
Car: 89' s13 soon to go ls1
has neone with a sr tried water injection over fmic just curios snow performance has a great kit and its susposed to work better
okevolution
Car: SR-Powered S13, 03 Evo8, 02 Civic Si
It should work very well at low boost without an intercooler. But it will need a tune as it messes with the AFR. I've ran WI on my Evo for 2 years and it allows you to run 12.0-12.5 AFRs without problems. Us Evo guys are big on using methonal or denatured alcohol mixed with water to run over 30psi on pump gas.
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
it depends on whether you mean spraying the i/c or spraying into the intake. spraying the i/c works marvellously, but if your i/c is way oversized (like ebay FMIC on stock turbo), then don't bother unless you just need something to do with your time and a couple dollars. if you mean spraying into the intake, good luck tuning. this does a great job, but not only will you need to retune, you'll need somebody good at tuning with water injection. not only will your A/F ratio be off, but the water itself throws off the precision of the wideband oxygen sensor. this is the main reason i don't use it. i don't know how it changes the reading, and the amount of change would change with the proportion of water to air/fuel mixture. basically, it would change, and the amount of change would constantly be changing, so you couldn't simply say "oh, it's the wideband times 85%."
that said, i agree with okevo, water injection can be awesome. i personally would rather have a bigger side-mount, or, having already done that myself, spray that i/c with water. if you spray enough water and mist it enough, you can get almost equally wicked results, but with little additional tuning or expense. either way you can use an ice water tank in the trunk to cool below ambient temperatures .
cobhc2889
so its basically more trouble than its worth
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Water Injection works awesome for my friends Supra. 630whp on 93 octane. Runs around 24psi from a T67. Hes got AEM EMS which is awesome to tune with.
Cyberkreig
Car: 1993 Nissan 240SX SR
Whatabout denaturated alcohol. Same system. far fewer problems than water.
