water in trunk
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
some time ago i've read someone has had a problem with water inside the trunk sitting in the bottom of the spare tire well. i have the same prob. i pulled out a little rubber seal in the bottom so it can drain but couldn't figure out where it's coming from. than i noticed that the left wheel well has some kind of a vent in it and i'm thinking maybe that's it. wouldn't worry too much about it but we've had rain for a month now and no end to it in sight.
anyone had the same issue?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
You might want to just take the car to a car wash and spray around to see if you can find the general area of the leak.
I'd suspect trunk lid seams before anything down low--water drains rearward from the car in large amounts and inevitably ends up in the seam. If any of the rubber seal is bad you'll get water in the trunk.
If you have a trunk spoiler, that could also be the culprit.
allensteiner
no spoiler, i also checked the rubber and when i open the wet lid water drains without getting into the trunk. good idea with the car wash though.
you know what i also noticed? i think that left wheel well vent inside the trunk opens when i drive and water gets in. the carpet is wet only on the left side and that vent is a little "screen" that hangs on a hinge and flaps loose.
one more thing...there is a small plastic handle in the right bottom corner in the trunk where the bottom and back of the seat meat. any idea what it's for? i don't think the back folds...and i don't think it's the emergency trunk release.
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
You should check in the gutters of the trunk (where the water goes out) see if there is any cracks or holes. My girl has the same problem it took me forever to find it but it was a very small crack in the metal where the water was coming in it was extremly hard to see but when i sealed it up it stopped. Water is a funny thing it allways wants to go down so even the slightest hole/crack and thats where it goes.
allensteiner
thanks, i'll go looking.
D_roc
Car: 2001 Maxima 20th aniv edition
check the taillights seal might want to take them out and re seal them wiht that black silicon
