Big-Bird »
https://forums.nicoclub.com/big-bird-u44704.html
Wed Mar 14, 2007 4:27 pm
The milky sustance you saw is what happens when oil mixes with water.
A pressure test of the coolant system would tell you if you have a coolant leak because all the pressure would bleed off very quickly. The test is very easy to conduct and most automtive parts stores that have a 'Tool Loan" program should have a pressure tester available.
Typical Coolant System Pressure Tester
Basically you do this with a cold engine and the motor off.
Remove the radiator cap.Attach the fitting from the kit to the radiator.Pressure up the system (to a max pressure as indicated by your factory radiator cap, usually 10-15 psi.) by either using the manual hand pump or using a regulated air supply.The gauge on the unit will tell you how much pressure is in the system and you can watch the needle for a drop in pressure. A small amount of leakage is normal but a quick drop indicates you either have a bad seal, or you have a lcoolant eak.
The milky stuff can also appear if you do lots of short trips. The reason is the engine oil needs to reach a certain temp for an extended period in order to flash off excess moisture ( condensation ) that forms inside your engine when you shut it off and allow it to cool. Try using a good full synthetic oil like Castrol 5W50 or Mobil 1. These synthetic oils are better able to resist sludge deposits and hinder the formation of the nasty milky oil.
By the way, sludge can't always be removed with just a simple engine flush. Switching to a good quality oil and taking your ride on a nice long highway drive ( About 2 hours will do a world of good ). It may take a few oil changes before you see any real improvements.
I have been on the Sytec regime since 1998 with my Nissan Trucks:
1. My 2000 Xterra has 140,000 km on it and not even a hint of sludge in the engine.
2. My 1995 Nissan Hardbody P/U had sludge in the motor when I bought it. I switched to Castrol Syntec and by the 4th oil change the engine had more pep and the sludge was all but gone. The sludge still did some damage though by plugging the hydraulic lifters because the darn things always ticked even after the oil pressure came up.
Good luck with your truck and I hope my info helps you out.
