nyckanny »
https://forums.nicoclub.com/nyckanny-u20768.html
Mon Oct 11, 2004 3:05 pm
Hi in my friends 95 s14, there is moisture in the spark plug chamber. I found this out after the car was rought idling. it would not have a steady idle in neutral, and bounces around. additionally the engine was shaking like crazy under the hood. so i pulled the plug wires out to see that there was moisture around the spark plug wire shaft. we cleaned that up with a towel. as well as put a screw driver with a dry towel inside to clean the channel in the engine head. so we started up the car after this, bang, idles great now. so i leave it on idle a little, drive around the block. then shut it down. a few minutes later, restarting the car, the idle is bad again, not as bad as before but still bad. check the plug wires again, same thing! theres water/moisture there again. there is only moisture in the 2nd, 3rd, and 4th plugs, when ur standing in front of the car with the hood open. strange thing that the water came back and the idle is funky again. so i dont have a plug socket right now. so i just pulled the wires out and left it there to air out overnight, we will see what happens tomorrow. where on earth could the water be coming from, maybe theres a coolant leak somewhere into the channel for the spark plugs?
thanks
