Water in my trunk!!!
rps13driver
Car: 1993 nissan 240sx
hey guys so its been a while since i lasted posted on here, but here it goes....so ive noticed in the last few weeks that ive had a pool of water in my trunk, i have no holes in my hatch nor do any cracks in my windshield. can you guys give me some ideas. the water is worrying me cuz i have my 12's and my 1000w amp in my trunk and i dont want the water to damage my stuff. thanks guys.
Warped161
Car: 90 s13 the never ending project
Yeah the water in the trunk is a common issue. it can be a tear in the weather seal or like my car it was coming through the small wire harness going to the hatch for the third light and defroster. remember the water can be leaking in and run along the plastic panels to end up in the trunk. hope this helps.
MR.chris
Car: 1995 Nissan 240sx se SR20DET Money Pit
The easiest way to find a leak in your trunk is to get a flash light and get inside the trunk and shut the lid. Then have a friend use a pressure washer or water hose and spray water all over your trunk. Then turn on the flashlight and find out where the water is coming from. Problem solved.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Water leaked into my trunk as well. I found that water that had collected and sat on top of my right side tail light was leaking in through the sealant where the tails are seated. You can check there, if that's the problem you can seal em up with silicone.
vancouverbc
Car: 1991 240sx
look up hatch in tutorials
locoluna825
Car: 90 240sx coupe
I havnt drivin my car since all this rain weve had here in socal. I started driving it a couple of days ago. I used my trunk yesterday and the carpet was wet. lifted up the carpet and cardboard and the whoole spare tire well was full of water... lol.
I checke dmy trunk seal by wiping it with chalk and it seals aroudn the body. wo i couldnt figure out were it was coming from.
I remmeber now when I first got the car. I had to change the taillights becuase the old ones were broken and i removed off the nasty gooey s***. I didnt know what it was for. I do now. LOL
n240sxfnatic
There is a rubber plug in the trunk/hatch area, pull it out and it will drain. I have to do it a lot.
speedeast
Glad I sparked your memory... I just have to remember to seal mine back up when I put my tails in.
nismoracingsx
Car: 1993 White 240sx Coupe
i took those rubber plugs out of my coupes trunk like forever ago..new tails and a trunk seal and that bisch still gets a little damp. So not it just auto drains itself all day long, lol.
P_856
Car: s13
i did the same thing but for my hatch resealed my taillights and got new weather stripping but it still leaks so i just leave the rubber drain plugs out
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
Lucky me, my trunk has no puddle, but there is some wetness. My key lock hole is allowing some water to pass thru it. I'm thinking of eliminating the key lock hole.
P_856
Car: s13
get some silicone and put it around the key lock hole
Steady_One_S13
Gee, i never thought of that. I'll try it out. Thanks!
speedeast
^When I saw the "gee" I thought he was being sarcastic, haha. Good luck with the leaks guys.
Steady_One_S13
^ No, not at all. It never crossed my mind to use clear silicone.
rps13driver
damn come to think of it....i remember that goooey stuff on the tails as well, thanks for the advice guys, hope i can solve my water issues....now i gotta get some silicone and go crazy! haha dont want anymore rust to get in my hatch....
