WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Jul 16, 2013 7:06 am
I've had surface rust on cams and on the cylinder walls of an RB20 that was exposed to weather. It was only surface rust though. There wasn't any pitting. Take some steel wool to the cams and see if there is pitting.
See if you can borrow a bore scope, pull a plug and look inside the cylinder. This is probably where rust would cause the most problems, like a massive loss of compression. I pulled the head off of mine and ran a bottle hone through all 6 cylinders to clean them up. Put everything back together and it ran fine with even compression across all 6 cylinders.
If you don't want to take it apart, spray some pb blaster or WD40 inside each cylinder, alot of it, and let it sit for a few hours. Then turn the crank a few times. Any surface rust should come off from the piston rings scraping the cylinder walls. After you rotate the crank, reinspect with a bore scope.
Best bet would be pulling the heads though. Anything else is fairly shade tree.
If you use a impact gun you can do a compression test on the cylinders to get a general idea if you have a cylinder that is really bad. You'll have to spray some oil in each cylinder though, you don't want to have metal on metal contact.
